How do I open Firefox
  • 1 பதிலளி
  • 1 இந்த பிரச்சனை உள்ளது
  • 7 views
  • Last reply by Yagmur
I downloaded Firefox on my IPhone; it shows up on my IPhone welcoming me but doesn’t open. How do I open Firefox.
Hi there,
Once you've downloaded and opened Mozilla Firefox, you can swipe to the left side through the information offered as a new user. Afterwards, you should be able to see the message at the bottom of the page that tells you to Start using Firefox.
You can try to double press the Home button and close the process of the app, then open it again. It will open normally.
Please let me know if you still encounter the issue even after performing the steps above.
